[Gdal-dev] ogr / geos scripting question
Ari Jolma ari.jolma at tkk.fi
Wed Sep 12 15:01:01 EDT 2007
I've done this a lot lately. I work with the Perl bindings, but
hopefully you get the idea. Here's a typical structure of a program:
use Geo::GDAL; # bring in the capability
$datasource = Geo::OGR::Open('.', 1) or die; # I've got shapefiles in
the current directory
$o = shift @ARGV; # read the name of the layer from command line
$out = $datasource->CreateLayer($o, undef, $Geo::OGR::wkbMultiPoint); #
a multipoint layer
$schema = $out->GetLayerDefn(); # an empty schema since I'm interested
in geometries now
# this is within a loop
# often the loop is from reading from another layer, for example:
# $input->ResetReading();
# while ($feature = $feature->GetNextFeature()) {
    $g = Geo::OGR::Geometry->new($Geo::OGR::wkbMultiPoint); # new geometry
    # a sub loop
      $p = Geo::OGR::Geometry->new($Geo::OGR::wkbPoint); # new point
      $p->SetPoint(0, $x, $y); # put the coords to the point
      $g->AddGeometry($p); # put the point to the multipoint
    $f = new Geo::OGR::Feature($schema); # new feature
    $f->SetGeometry($g); # put the geometry to the feature
    $out->CreateFeature($f); # put the feature to the layer
# out of the loop and finish:
$out->SyncToDisk;
Brian Hamlin kirjoitti:
> I'd like to write a script to add a few points to a datasource, then
> make some simple geos calculations on it.
>  (I'm completely new to this)
> below is what I came up with at a first look ( to simply create the
> Data).
> After creating the Data, I'd like to make a geos calculation, like
> minimum radius for example.
> thanks in advance
>   -Brian / darkblueB
> get OGR driver count
>    iterate through drivers, looking for the desired named driver
> datasource = driver->CreateDataSource( dir )
> layer = datasource->CreateLayer( "layerOne" )
> g = OGR CreateGeometryFromWKT( "Point( 10 100)" )
> layer->SyncToDisk
> I am a little lost about the need for features, or how to append my new
> OGRGeometryShadow to the layer.
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Prof. Ari Jolma
Geoinformaatio- ja paikannustekniikka / Geoinformation and positioning
Teknillinen Korkeakoulu / Helsinki University of Technology
tel: +358 9 451 3886 address: POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
