[Gdal-dev] Fwd: plate carree to latlon projection problem
jjknoops at netscape.net jjknoops at netscape.net
Mon Sep 17 09:37:14 EDT 2007
Hello Everybody,
I am using gdal for a couple of year now and I am very satisfied with it.
But now i have a problem with reprojecting from and to plate
carree(epsg:32662).
I have data in plate carree and I need to reproject to latlon but i there is an
offset between the results and other data that already in latlon.
I have also used Erdas Imagine 9.1 to do the reprojecting but i get a different
results then from gdal. The results from Erdas are beter then from gdal
After testing it with a worldwide dataset. I found that the
offset is almost 0 at (0,0) to several km around Brittian. Is there a problem
with the reprojection using plate carree or do you use a different wgs84 then
Erdas?
I am using gdal from fwtools 1.3.6
Best Regards,
Jaap Knoops
Check Out the new free AIM(R) Mail -- Unlimited storage and industry-leading spam and email virus protection.
________________________________________________________________________
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070917/40b05f49/attachment.html
