[Gdal-dev] HTTP driver dependency
Wed Sep 26 02:03:41 EDT 2007
On 9/25/07, Howard Butler <hobu.inc at gmail.com> wrote:
> Mateusz,
> Oops, this is my fault.  I think we should no-op ImportFromUrl if
> curl is not available, and I forgot to do so when I wrote it.
Howard / Mateusz,
The dependencies on curl are supposed to be resolved at
the gdal/port/cpl_http.cpp level.  The CPLHTTPFetch() function
should just return an error at runtime when curl is not available.
I don't understand why we should see a direct dependency on
curl from the importFromUrl.
Perhaps the two of you can chat with me tomorrow if the
solution is not obvious.
Best regards,
