[Gdal-dev] gdal_translate unable to allocate buffer
Even Rouault even.rouault at mines-paris.org
Thu Sep 27 14:50:13 EDT 2007
Hello,
Can you provide more info on your source file : pasting the result of gdalinfo
on it would be a start.
Can you also paste your  gdal_translate command line ?
Even
On Thursday 27 September 2007 20:36:46 WolfgangZ wrote:
> I got an error from gdal_translate, has anybody an idea what the cause
> could be?
> Regards
> Wolfgang
> ERROR 1: GetBlockRef failed at X block offset 6, Y block offset 1
> ERROR 2: Unable to allocate 196608 bytes for a temporary strip buffer in
> GTIFF d
> river.
> ERROR 1: IReadBlock failed at X offset 6, Y offset 1
> GTIFF d
> river.
> ERROR 1: IReadBlock failed at X offset 7, Y offset 1
> ERROR 1: GetBlockRef failed at X block offset 7, Y block offset 1
> GTIFF d
> river.
> GTIFF d
> river.
> GTIFF d
> river.
> ERROR 1: IReadBlock failed at X offset 0, Y offset 1
> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 1
> GTIFF d
> river.
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
