[gdal-dev] updating a HFA image
Limei Ran lran at unc.edu
Wed Apr 2 09:38:28 EDT 2008
Hi Frank:
The original image file was a USGS NLCD landuse image (I think it was
created in the IMAGINE package).   I used
poRDataset->GetDriver()->CopyFiles made a copy.  Then, I updated the
copied file.  I will file a ticket with a small area result.
For a quick solution, could I translate the image into an EHdr format
image using gdal_translate and then update it with EHdr format or other
better format you may suggest for reading a region from the image?
Thank you very much,
Limei
Frank Warmerdam wrote:
> Limei Ran wrote:
>> Hi:
>> I opened an HFA image and got a band from it (only 1 band image).  I
>> read a region from the band and update the band with the updated array.
>> But, for somehow, I can not view the updated HFA image in arcGIS due
>> to building pyramids failed.  Could you give me some ideas about what
>> may go wrong?  Here are codes related:
> Limei,
> I don't see any problem in your code.
> Is the original imagine file created with GDAL or with imagine or arcgis?
> In place update of anything other than uncompressed image data may not
> work
> well for imagine files not created with GDAL.
> If you can isolate this to a small file then you could file a ticket,
> attaching the before and after .img files and explaining as best as
> possible
> what goes wrong in ArcGIS.
> Best regards,
