[gdal-dev] updating a HFA image
Wed Apr 2 10:22:43 EDT 2008
Limei Ran wrote:
> Hi Frank:
> The original image file was a USGS NLCD landuse image (I think it was
> created in the IMAGINE package).   I used
> poRDataset->GetDriver()->CopyFiles made a copy.  Then, I updated the
> copied file.  I will file a ticket with a small area result.
Cool, thanks
> For a quick solution, could I translate the image into an EHdr format
> image using gdal_translate and then update it with EHdr format or other
> better format you may suggest for reading a region from the image?
That should work, or I presume you could even use the Driver CreateCopy()
method to copy the image contents, instead of literally copying all the
component files.  This would give you a GDAL generated .img file that
should hopefully be more safely updated.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
