[gdal-dev] Ogr2ogr, shp-dgn conversion
Olof Landahl Olof.Landahl at carmenta.com
Wed Apr 23 03:38:50 EDT 2008
> I'm using ogr2ogr (included in gdal) to convert a shapefile to
> Microstation DGN format. The conversion does the job, except that
> polygons and line strings with too many (38) vertices are converted
> into complex shapes. What is the reason for this?
> When I open the DGN-file in Microstation the complex shapes are
> visible but not possible to select or edit without a lot of work with
> special tools. Can I do something in the conversion with ogr2ogr to
> prevent it from creating complex shapes or to make the complex shapes
> selectable?
> /Olof Landahl
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080423/e21dae76/attachment.html
