[gdal-dev] Ogr2ogr Pgeo to SQL?
Dane Springmeyer blake at hailmail.net
Wed Apr 23 11:50:23 EDT 2008
I've been using the PGeo driver on a windows machine to convert ESRI
geodatabases/Access Databases (.mdb) to shapefiles (I have not got the
driver working yet on linux). Now, I'd like to send directly to
PostgreSQL (so all of my column names are not truncated), but I run my
Postgres Server on a separate, non networked linux machine. As such,
I'd like to use Ogr2ogr to create intermediate output, ideally a sql
insert statement like shp2pgsql does.
My sense is that the ogr2ogr utility is not built this way (there is
no SQL format specifically) and I'd be best off to actually spend the
time to network my machines. Anyone have suggestions about other
approaches? Perhaps there is a crafty way to capture the insert
statement ogr2ogr is making and write it to a file?
Thanks,
Dane
