FW: [gdal-dev] RE: ogr2ogr PostgreSQL to shp
Randy George rkgeorge at cadmaps.com
Sat Apr 26 15:38:23 EDT 2008
Hi Frank,
> This can happen if you have a geometry_columns table but no entries in it.
Yes, that was the problem. I've been burned on that before so I should have
noticed. It's too easy to use backup/restore when moving from system to
system and forget the geometry_columns update.
Thanks
randy
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Saturday, April 26, 2008 10:15 AM
To: rkgeorge at cadmaps.com
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] RE: ogr2ogr PostgreSQL to shp
Randy George wrote:
> Hi,
> I'm attempting to extract a subset of a PostGIS table to shp using this
> windows command line:
> "C:\Program Files\FWTools2.1.0\bin\ogr2ogr" --debug on -where " fips =
> '08041' " -f "ESRI Shapefile" out.shp PG:"user=user dbname=db
> host=localhost password=pass port=5432" gnis
> Here is the debug output:
> OGR_PG: DBName="db"
> OGR_PG: PostSIS version string: '1.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1'
> -> '1.3'
> OGR_PG: POSTGIS_VERSION=1.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
> ERROR 1: PG:user=user dbname=db host=localhost password=pass port=54
Randy,
Does ogrinfo on this postgres database work?  The fact that you got the
postgis version info back indicates that the database was successfully
connected to.
Skimming the Postgres driver code, I suspect it failed to identify any
layers in your postgres database.  This can happen if you have a
geometry_columns table but no entries in it.  I'm not sure why else it
might happen.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
