[gdal-dev] Overview building broken
    Benoît Andrieu
    bea at ixsea.com
    Wed Dec 10 08:02:15 EST 2008
Hi all !
I am using FWTools 2.2.6 and have some problems with the overview
building...
I just tried the 2.2.8 release, same result !
My software tries to build a x level overview pyramid on a GTiff.
I am using the following code :
CPLErr statut_generation_pyramidage =
gdal_dataset_copie->BuildOverviews("average", nb_pyramidage, anOverviewList,
0, NULL, NULL, NULL);
The function is returning CE_Failure and the console has a lot of messages
which appears on the call of the BuildOverviews' method.
ERROR 1: TIFFSetField:f:\test_isdas\PIC_CONT_SS_F_4_8bit.TIF: Cannot modify
tag "Compression" while writing
tag "ImageWidth" while writing
tag "PlanarConfiguration" while writing
tag "BitsPerSample" while writing
tag "SamplesPerPixel" while writing
tag "PhotometricInterpretation" while writing
tag "SampleFormat" while writing
tag "TileWidth" while writing
tag "TileLength" while writing
ERROR 1: GTIFFWriteDirectory:Can not write tiles to a stripped image
The complete call sequence is (without some instanciations) :
  GDALDataset* gdal_dataset_copie = poDriver->CreateCopy(string_fileOut,
gdal_dataset, TRUE, options_, NULL, NULL);
  char **options = 0;
  GDALDriver *gdal_driver = GetGDALDriverManager()->GetDriverByName("MEM");
  GDALDataset* gdal_dataset = gdal_driver->Create("", image->Get_Largeur(),
image->Get_Hauteur(), nbCanaux, depth, options);
  gdal_dataset->FlushCache();
  gdal_dataset->GetRasterBand(1)->SetColorInterpretation(GCI_GrayIndex);
  // Filling the dataset with data
  GDALDriver *poDriver = GetGDALDriverManager()->GetDriverByName("GTIFF");
  char **options_ = 0;
  options_ = CSLSetNameValue( options, "INTERLEAVE", "PIXEL" );
  gdal_dataset->SetProjection( string_WKT );
  gdal_dataset->SetGeoTransform( m_P_D_TFW );
  gdal_dataset_copie->FlushCache();
  gdal_dataset_copie->GetRasterBand(index_band)->SetColorInterpretation(poBand->GetColorInterpretation());
  delete gdal_dataset_copie;
  delete gdal_dataset;
This code was working with FWTools 1.3.2. I don't know what to do now... I
don't want to close the dataset, reopen it, build overview, close the
dataset because of the loss of performance (which is really important).
Any idea ?
Thanks in advance !
Best regards,
Benoît Andrieu
+33.(0)1.30.08.95.21
bea at ixsea.com
