[gdal-dev] Zonal statistics with GDAL/StarSpan
Greg Ederer greg at ergonosis.com
Thu Dec 18 14:32:30 EST 2008
Hi Brent,
Thanks for the example.  Here's what I got:
Macintosh-4:starspan_tests gregederer$ starspan2 --progress --RID none
--vector
/Users/gregederer/servers/geoserver_data/data/shapefiles/Admin/afadmn2n.shp
--raster rfe_2006_04_pct.tif --stats  results.txt avg
starspan: --out-prefix: ?
Type `starspan --help' for help
I then added a --out-prefix, like so:
--vector
--raster rfe_2006_04_pct.tif --stats  results.txt avg --out-prefix bar
starspan: --out-type: ?
I then added '--out-type table' (I found in the source that valid
--out-types are: table, mini_raster_strip, mini_rasters, rasterization):
--vector
--out-type table
Number of features: 550
starspan_csv:   1: Extracting from rfe_2006_04_pct.tif
        0% terminate called after throwing an instance of
'geos::util::TopologyException'
  what():  TopologyException: side location conflict -8.25 23.1536
Abort trap
Any idea what the TopologyException indicates?
Thanks!
Greg
Brent Fraser wrote:
> Greg,
>  I've used StarSpan to do similar things; in my case I wanted "mode"
> not "avg".  Using v1.2.01 (I don't think I made major mods to the
> source):
>     starspan2.exe --progress --RID none --vector boundaries.shp
> --raster big.tif --stats  results.txt mode
> I edited the resulting results.txt text (csv) file and used GDAL's
> ogr2ogr to do a join on the shapefile's DBF file based on the FID.
> Brent Fraser
> Greg Ederer wrote:
>> Hello all,
>> I'm a GDAL newbie.  I have a shape file containing subnational
>> boundaries for Africa.  I have a raster containing rainfall for
>> Africa.  I need to pull out the spatial average of rainfall for each
>> of the subnational units.
>> I think that I might be able to pull this off using StarSpan.  But,
>> the docs on the StarSpan wiki do not line up with the current version
>> of the program (the changelog mentions that certain command line
>> switches have been eliminated, and others added; but it doesn't say
>> what the new switches do, or how to use them).  I am digging through
>> the StarSpan sources to try to figure out how to use it.
>> Does anyone have any suggestions as to how I might get the needed
>> data using GDAL (with, or without StarSpan)?
>> Thanks!
>> Greg
| E R G O N O S I S
| Greg Ederer
| Lead Developer
| 360.774.6848
