[gdal-dev] Zonal statistics with GDAL/StarSpan
Brent Fraser bfraser at geoanalytic.com
Thu Dec 18 14:57:28 EST 2008
Greg,
  It means the GEOS topology library is having problems with geometry of your input shapefile.  Most likely related to duplicate vertices (or near-duplicate) in a polygon.  Do a Google for "side location conflict".   It would be nice if it spat out the FID of the offending polygon...
Brent
Greg Ederer wrote:
> Hi Brent,
> Thanks for the example.  Here's what I got:
> Macintosh-4:starspan_tests gregederer$ starspan2 --progress --RID none
> --vector
> /Users/gregederer/servers/geoserver_data/data/shapefiles/Admin/afadmn2n.shp
> --raster rfe_2006_04_pct.tif --stats  results.txt avg
> starspan: --out-prefix: ?
> Type `starspan --help' for help
> I then added a --out-prefix, like so:
> --vector
> --raster rfe_2006_04_pct.tif --stats  results.txt avg --out-prefix bar
> starspan: --out-type: ?
> I then added '--out-type table' (I found in the source that valid
> --out-types are: table, mini_raster_strip, mini_rasters, rasterization):
> --vector
> --out-type table
> Number of features: 550
> starspan_csv:   1: Extracting from rfe_2006_04_pct.tif
>        0% terminate called after throwing an instance of
> 'geos::util::TopologyException'
>  what():  TopologyException: side location conflict -8.25 23.1536
> Abort trap
> Any idea what the TopologyException indicates?
> Thanks!
> Greg
> Brent Fraser wrote:
>> Greg,
>>  I've used StarSpan to do similar things; in my case I wanted "mode"
>> not "avg".  Using v1.2.01 (I don't think I made major mods to the
>> source):
>>     starspan2.exe --progress --RID none --vector boundaries.shp
>> --raster big.tif --stats  results.txt mode
>> I edited the resulting results.txt text (csv) file and used GDAL's
>> ogr2ogr to do a join on the shapefile's DBF file based on the FID.
>> Brent Fraser
>> Greg Ederer wrote:
>>> Hello all,
>>> I'm a GDAL newbie.  I have a shape file containing subnational
>>> boundaries for Africa.  I have a raster containing rainfall for
>>> Africa.  I need to pull out the spatial average of rainfall for each
>>> of the subnational units.
>>> I think that I might be able to pull this off using StarSpan.  But,
>>> the docs on the StarSpan wiki do not line up with the current version
>>> of the program (the changelog mentions that certain command line
>>> switches have been eliminated, and others added; but it doesn't say
>>> what the new switches do, or how to use them).  I am digging through
>>> the StarSpan sources to try to figure out how to use it.
>>> Does anyone have any suggestions as to how I might get the needed
>>> data using GDAL (with, or without StarSpan)?
>>> Thanks!
>>> Greg
