[gdal-dev] OGR and VPF
Chris Barker Chris.Barker at noaa.gov
Tue Feb 5 23:15:47 EST 2008
Even Rouault wrote:
> In fact, OGDI *used to be* very case sensitive. If you use OGDI from its CVS
> repository, it should be much more tolerant towards case sensitiveness.
Good to know.
> Note that it's important not to include the final slash in your gltp: "URL",
> so gltp:/vrf/path_to_c0a26a is fine, but not gltp:/vrf/path_to_c0a26a/ .
Thanks, I'll give that try when I get back in the office -- I'm on
travel now.
> Note, I've tried to download some DNC on the
> http://www.nga.mil/portal/site/dnc/ NGA site, but I can't find full libraries
> to download. Instead it only offers 'patches' with which I don't know what to
> do.
I had the same problem, but with enough poking around I finally found
the full data -- that site is poorly designed in that regard.
 From the main page, pick a region.
Then go to the "library coverage group" box, and pick a "Coverage
Group". You should then get page where you can check the "download full
library" box.
- Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
