[gdal-dev] HFA RRD bug
Even Rouault even.rouault at mines-paris.org
Sun Feb 10 05:46:19 EST 2008
Martin,
Yes, it's a known bug of GDAL 1.5.0. See ticket
http://trac.osgeo.org/gdal/ticket/2145.
I've submitted a patch that checks for the NULL pointer and it seems to fix
the problem. I'm not sure this is the correct fix however, but hopefully, an
appropriate fix should go to GDAL 1.5.1.
Best regards
Le Sunday 10 February 2008 04:52:00 Martin Chapman, vous avez écrit :
> call always returns NULL and then there is no check for NULL after that on
> line 519 which causes the application to seg fault.
