[gdal-dev] HFA RRD bug
Martin Chapman mchapman at texelinc.com
Sat Feb 9 22:52:00 EST 2008
In the file c:\software\gdal\gcore\gdaldefaultoverviews.cpp in the function
GDALDefaultBuildOverviews::BuildOverviews() on line 517 when I try to build
overviews for an erdas imagine file .img and using USE_RRD=YES config option
the
poOverDS = poBand->GetDataset();
call always returns NULL and then there is no check for NULL after that on
line 519 which causes the application to seg fault.
poOverDS->oOvManager.poBaseDS = poDS; // KABOOM!!! because poOverDS is NULL.
Is this a bug?  Where should the dataset of the band be assigned during the
overview creation process?
Best regards,
Martin Chapman
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080209/15157076/attachment.html
