[gdal-dev] Open source API to convert raster to polygons?
Chris Barker Chris.Barker at noaa.gov
Thu Jan 10 14:18:34 EST 2008
Ricardo Scachetti Pereira wrote:
>    What I really need is some API or software library (preferably in C
> or C++) that I could use to convert ESRI Arc/Info Grids (the binary
> kind) to a Shapefile of polygons.
Well, no, that doesn't answer the question at all. Polygons and Raster
data are completely different concepts. Raster data is one or more
values at a bunch of points on a grid -- what do you want your polygons
to represent? I can think of two fairly obvious possibilities:
1) There are polygons visually represented in the raster -- maybe is was
actually created by rendering polygons in the first place (like a map
with boundaries or something). In this case, you're looking for line
tracing or edge-detection tools.
2) Your raster represent some continuous field, like elevation n a DEM .
In this case, you might want to contour the data, and get the contours
as polygons. If this is the case, look for contouring code.
There are probably an infinite number of other ways one might want to
extract polygons from raster data -- we need to know what you're trying
to do to help any more.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
