[gdal-dev] gdal_merge multiple files
Matt Wilkie matt.wilkie at gov.yk.ca
Thu Jan 10 18:33:21 EST 2008
> It seems that gdal_merge does not like globbing.  Are there other
> ways of getting a list of images into gdal_merge without putting them
> all on the command line?  I think I did this once before with a
> similar gdal command but used a config file???
I created a batch file for this purpose, which is attached.
I also just added it and Adam's example using --optfile to
http://trac.osgeo.org/gdal/wiki/UserDocs/GdalMerge
Please amend or enhance as required.
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
@echo off
:: initial version, 2005-Nov-17, matt wilkie
:: this script is public domain
if [%1]==[] (
	echo.
	echo -={ gdal_wildmerge }=- Allow gdal_merge to accept wildcards for input files
	echo .
	echo . 	gdal_wildmerge.bat [input-file-wildcard] [output-file] {options}
	echo .
	echo .	gdal_wildmerge d:\src\*.tif mosaick.tif -init -9999
	echo.
	goto :EOF
	:: %1 is the input wildcard mask
	:: This is inverted from normal gdal_merge usage in order to allow other
	:: options be passed to gdal_merge
:: delayed expansion requires windows NT or later command shell
:: (it won't work on windows 9x)
	verify other 2>nul
	setlocal ENABLEDELAYEDEXPANSION
	if errorlevel 1 goto :wrong_version
:: gdal_merge won't overwrite an existing file
	if exist %2 goto :file_exists
:: Build the input file list
	set infiles=
	for %%a in (%1) do set infiles=!infiles! "%%a"
:: Here is were the actual work happens
	set gdalcmd=gdal_merge %infiles% -o "%2"
   echo %gdalcmd%
   :: IMPORTANT, if gdal_merge is not call'ed control doesn't return
	:: to the batch file
	call %gdalcmd%
	goto :EOF
:file_exists
	echo *** the output file "%2" already exists.
	goto :EOF
:wrong_version
	echo.
	echo	Sorry, this batchfile requires DELAYED EXPANSION which is
	echo	not available in this shell. See
	echo  http://www.google.com/search?q=enabledelayedexpansion
	goto :EOF
