[gdal-dev] C# OGRSpatialReference class -SetLinearUnits or SetLinearUnitsAndUpdateParameters()?
Mark Cheyne cheynm at yahoo.com
Thu Jan 17 10:14:23 EST 2008
The class documentation for the OGRSpatialReference
class
(http://www.gdal.org/ogr/classOGRSpatialReference.html)
describes two methods to set the linear units of a
projected coordinate system:
* SetLinearUnits() -
http://www.gdal.org/ogr/classOGRSpatialReference.html#2016fee7b234666c5e94d528661e6729
* SetLinearUnitsAndUpdateParameters() -
http://www.gdal.org/ogr/classOGRSpatialReference.html#daab3d6e836f93974022bd78e221c4b4
Using C# with the binaries/wrappers that come with
FWTools 2.0.3, the second method does not appear on
this class.
* Is its absence intentional or accidental?
* When is it appropriate to use one or the other?
I am having trouble creating a correct NAD83HARN UTM
zone 15N PCS in units of feet.
Look at the code below, and the Proj4 and WKT it
produces. I think the false easting is getting wonked
- note the Proj4 says it is 152,400.3 feet, but the
WKT says it is 500,000 meters. Seems like a meters
conversion is getting misapplied? Or am I using the
class incorrectly?
OSGeo.OSR.SpatialReference sr = new
SpatialReference("");
sr.SetProjCS("NAD83(HARN) / UTM zone 15N");
sr.SetWellKnownGeogCS("EPSG:4152");
sr.SetUTM(15, 1);
sr.SetLinearUnits(Constants.SRS_UL_US_FOOT,
Constants.SRS_UL_US_FOOT_CONV);
The Proj.4 params I get:
+proj=tmerc +lat_0=0 +lon_0=-93 +k=0.9996
+x_0=152400.3 +y_0=0 +ellps=GRS80 +units=us-ft
+no_defs
The WKT I get:
PROJCS["NAD83(HARN) / UTM zone 15N",
    GEOGCS["NAD83(HARN)",
        DATUM["NAD83_High_Accuracy_Regional_Network",
            SPHEROID["GRS 1980",6378137,298.257222101,
                AUTHORITY["EPSG","7019"]],
            AUTHORITY["EPSG","6152"]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG","8901"]],
        UNIT["degree",0.01745329251994328,
            AUTHORITY["EPSG","9122"]],
        AUTHORITY["EPSG","4152"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-93],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["U.S. Foot",0.3048006]]
Mark Cheyne
(608) 332-2235 (cell)
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
