[gdal-dev] _gdal.py: cannot find _gdal.GDALGetFileList
Tue Jan 22 10:15:06 EST 2008
Yann Chemin wrote:
> Hello,
> While doing this:
>  papszFileList = _gdal.GDALGetFileList( hDataset )
> it gave this error:
>  AttributeError: 'module' object has no attribute 'GDALGetFileList'
> The imported modules are:
>  import _gdal
>  import gdal
>  from gdalconst import *
> Am I missing something?
> thank you for any suggestion...
Yann,
GDALGetFileList() is new to GDAL 1.5.0, and likely only exists in the
modern Python bindings (not the antique bindings distributed in FWTools
or built using --with-ogpython).
Is it possible that you are using an older GDAL or a new GDAL with old
bindings (ie. FWTools)?
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
