[gdal-dev] RV: RGB Tiled - non Tiled Images
Mendizabal Vicente, Ainhoa amendizabal at indra.es
Wed Jul 2 02:32:07 EDT 2008
I was trying to generate an RGB non-tiled image from a Grey tiled Image like this:
            GDALAllRegister();
            GDALDataset *m_InputImage;
            GDALRasterBand *InputRasterBand;
            m_InputImage = (GDALDataset*)GDALOpen("D: \\DAT_01.001_tiled.tif", GA_ReadOnly);
            char **papszOptions = NULL;
            papszOptions = CSLSetNameValue(papszOptions, "TILED", "YES");
            GDALDataset *m_OutputImage = (GDALDataset*)GDALCreate(m_InputImage->GetDriver(), D:\\Remuestreo.tif", 1024, 1024, 3, GDT_Byte, papszOptions);
            GDALRasterBand *OutputRasterBand;
            int rowTile;
            int colTile;
            int colOff = 3;
            int rowOff = 3;
            int band;
            InputRasterBand = m_InputImage->GetRasterBand(1);
            unsigned char* Buffer;
            Buffer = (unsigned char *) malloc(256*256*sizeof(unsigned char));
            for(rowTile = 0; rowTile < 4; rowTile ++)
                        for(colTile = 0; colTile <4; colTile++)
                                   for(band = 1; band<=3; band ++)
                                               InputRasterBand->ReadBlock(colTile + colOff, rowTile + rowOff, (void*)Buffer);
                                               OutputRasterBand = m_OutputImage->GetRasterBand(band);
                                               OutputRasterBand->WriteBlock(colTile, rowTile, (void*)Buffer);
    GDALDataset *OutputShown2;
    OutputShown2 = m_OutputImage->GetDriver()->CreateCopy("D\\RemuestreoShown.tif", m_OutputImage, false, NULL, NULL, NULL);
    free(Buffer);
    GDALClose(m_OutputImage);
    GDALClose(OutputShown2);
But I could not view properly the resulting image.
Looking for the original problem I've tried simply to transform a RGB non-tiled Image to tiled, and then I've made it non-tiled again:
gdal_transform -co 'tiled=yes'    Original.tif         Tiled.tif
gdal_transform -co 'tiled=no'      Tiled.tif             Result.tif
but, I can't view properly the Image Result.tif. ¿What I've made wrong?
Thank you
Ainhoa
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080702/521e0110/attachment-0001.html
