[gdal-dev] densify line?
Matt Wilkie matt.wilkie at gov.yk.ca
Thu Jul 10 12:58:46 EDT 2008
Hello All,
Does ogr have a densify line option or utility?
The goal is to densify (add vertices at regular intervals) to a 1
dergree by 1 degree fishnet grid before projecting from WGS84 to UTM (or
whatever) so the result follows earth curvature rather then jumping
straight from corner point to corner point.
I could use Arcinfo DENSIFYARC, but would like to avoid having to
convert to a coverage if I can.
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
