[gdal-dev] densify line?
Thu Jul 10 13:29:28 EDT 2008
Matt Wilkie wrote:
> Hello All,
> Does ogr have a densify line option or utility?
> The goal is to densify (add vertices at regular intervals) to a 1
> dergree by 1 degree fishnet grid before projecting from WGS84 to UTM (or
> whatever) so the result follows earth curvature rather then jumping
> straight from corner point to corner point.
> I could use Arcinfo DENSIFYARC, but would like to avoid having to
> convert to a coverage if I can.
Matt,
No, no such capability exists in OGR to the best of my knowledge.
The Value() method on OGRCurve might be helpful to identify points along
a line string at particular distance intervals.
  * \fn void OGRCurve::Value( double dfDistance, OGRPoint * poPoint ) const;
  * Fetch point at given distance along curve.
  * This method relates to the SF COM ICurve::get_Value() method.
  * @param dfDistance distance along the curve at which to sample position.
  *                   This distance should be between zero and get_Length()
  *                   for this curve.
  * @param poPoint the point to be assigned the curve position.
If someone were inclined to implement it, I think a Densify() method
on OGRGeometry would be nice.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
