[gdal-dev] densify line?
Even Rouault even.rouault at mines-paris.org
Thu Jul 10 16:50:19 EDT 2008
For your information, I've just added in GDAL trunk a segmentize() method to
OGRGeometry and a "-segmentize" option to ogr2ogr.
Le Thursday 10 July 2008 18:58:46 Matt Wilkie, vous avez écrit :
> Hello All,
> Does ogr have a densify line option or utility?
> The goal is to densify (add vertices at regular intervals) to a 1
> dergree by 1 degree fishnet grid before projecting from WGS84 to UTM (or
> whatever) so the result follows earth curvature rather then jumping
> straight from corner point to corner point.
> I could use Arcinfo DENSIFYARC, but would like to avoid having to
> convert to a coverage if I can.
> thanks,
