[gdal-dev] Bindings for the histogram method of band
Howard Butler hobu.inc at gmail.com
Tue Jul 22 17:57:37 EDT 2008
On Jul 22, 2008, at 9:48 AM, Ari Jolma wrote:
> The trac.osgeo.org does not answer so I'll put this here.
> Hobu, would it be ok to have (int len, int *output) typemap. They
> can be used in GetHistogram method like this (note that the API is
> same for C# but it must use different typemaps. From Band.i:
> %typemap(check) (int len, int *output)
> /* %typemap(check) (int len, int *output) */
> if ($1 < 1) $1 = 1; /* stop idiocy */
> $2 = (int *)CPLMalloc( $1 * sizeof(int) );
Ari,
This isn't too different from what I proposed except for I think that
abusing the check typemap like that (malloc'ing the integer array) is
a recipe for disaster.  The check typemap could possibly be run
multiple times, right?  Otherwise, it looks pretty close to what I had
for a proposal http://trac.osgeo.org/gdal/changeset/14941 .
I'm open to changing the GetHistogram function signature within Band.i
however you guys wish (ideally to support just using  (int len, int
*output) and not having a special typemap for just this function), and
while it would be nice that we wouldn't need the #ifdefs for every
possible language we might ever support ;), it's not the end of the
world either...
Howard
