[gdal-dev] GDALSetGeoTransform, & using masks
Patrick Cannon patrick.cannon at barcosoft.com
Fri Jul 25 11:34:49 EDT 2008
Hello Everyone,
I have what I hope to be just a couple of quick questions.
I am in the process of writting my own driver/dataset for BSB files so I can
support version 4 and 5 files.  This way the code for handling these files
is not in the standard GDAL library and should isolate it from Maptech.
I have run into a bit of a snag though.  Is it possible to create an affine
transform matrix from the GCP values?  Or could I use Polynomial X to L, Y
to L, L to X and L to Y values?
I have a class to handled the Polynomials and convert between Map to Pixel
and Pixel to map but, I do not see a clean way of implementing this within
the GDAL framework.
My next question has to do with masks.  For example, the chart image has a
white border around it and I do not want it to show/count when asking the
dataset to build the image.  This is further complicated by needing to use
a polygon instead of a rectangle to describe the visible part of the image.
Is it possible to use a mask to hide the unwanted portion?
Even if I am only reading part of the image?
Is there an example somewhere on how to do this?
Is there a better way to handle this?
Thank you for any help or guidance you can provide.
Best regards,
Patrick Cannon
