[gdal-dev] OT: subversion configuration
Christopher Schmidt crschmidt at metacarta.com
Sat Jul 26 18:08:06 EDT 2008
On Fri, Jul 25, 2008 at 01:22:24PM -0400, Norman Vine wrote:
> Ari Jolma writes:
> > I'm annoyed because I can't configure subversion properly for
> > my local
> > copy of GDAL repository.
> > I want to keep all files locally LF also in Windows. I've set
> AFAIK the easiest way to do this is to use the Cygwin tools
> Your local SVN repository will need to be on a Unix Mount
>  http://cygwin.com/cygwin-ug-net/using-textbinary.html
Agreed. If you want Unix-style file endings, using the Cygwin class of
tools will get you that, since Cygwin acts like a Unix tool.
Christopher Schmidt
