[gdal-dev] OT: subversion configuration
Ari Jolma ari.jolma at tkk.fi
Sun Jul 27 06:10:33 EDT 2008
Christopher Barker kirjoitti:
>> I assume I shouldn't set the property to LF for files which I don't
>> "own" (everything else than the Perl bindings)?
> The trouble is that even though you are the primary editor of the Perl
> bindings, others will, at the very least, check out the files and look
> at them or compile them. I don't think it's a good idea to have
> different systems for different parts of the the same project --
> wouldn't it get messy for you, if no one else?
you're probably right
> Why do you need LF on Windows? Why not just use Windows line endings
> on windows? With a decent editor is should be completely transparent
> anyway.
I use emacs for editing and while there may be a way to configure it to
not to show the ^M, I don't know it.
> Ideally, your SVN client would let you define what "native" linefeeds
> mean to you, but I don't know that Tortoise (or any other) client
> supports that. You might try a feature request.
I thought so too.
Ari
