[gdal-dev] XY Point extraction from raster
Hyer, Dr. Edward (Post Doc) edward.hyer.ctr at nrlmry.navy.mil
Fri Jun 27 20:34:26 EDT 2008
I have been very pleased with the way I can use 'gdaltransform' to wrap
a long set of operations into a single-line command. I am trying to
extract point data from an HDF file, and with:
gdaltransform -i -t_srs EPSG:4326 HDF_FILE.hdf < points_dd.txt >
points_xy.txt
I can feed it a set of XY geographic locations, and it will spit out
corresponding image coordinates.
Now, how can I actually pull the data, just for those specific
coordinates?
I use PDL in Perl for numerics, but this seems like something I should
be able to do with the command-line utilities.
Thanks for any tips/tricks,
--Edward H.
Dr. Edward J. Hyer
Post-Doctoral Researcher
Naval Research Laboratory
Marine Meteorology Division
7 Grace Hopper Avenue, Stop 2
Monterey, California 93940
831-656-4023
FAX 831-656-4769
edward.hyer at nrlmry.navy.mil
