[gdal-dev] Loading from a stream/memory rather than a file
Martin Chapman mchapman at texelinc.com
Fri Mar 7 17:48:51 EST 2008
Cristiaan,
Here's another way to do it that is really easy too...maybe it is the same
thing?  I create a MEM dataset from a raster file but you could easily load
it with bytes from memory.
GDALDataset* pDataSource = (GDALDataset*) GDALOpen(sFileName.c_str(),
(GDALAccess) 0);
if (!pDataSource)
	return AtlReportError(GetObjectCLSID(), _T((TCHAR*)
CPLGetLastErrorMsg()));
int nBandCount = pDataSource->GetRasterCount();
int nWidth = pDataSource->GetRasterXSize();
int nHeight = pDataSource->GetRasterYSize();
GDALDataType eBandType = pDataSource->GetRasterBand(1)->GetRasterDataType();
GDALDriver* pMemDriver = GetGDALDriverManager()->GetDriverByName("MEM");
if (!pMemDriver)
GDALDataset* pMemDataset = pMemDriver->Create(sStreamId.str().c_str(),
nWidth, nHeight, nBandCount, eBandType, NULL);
if (!pMemDataset)
for (int i = 0; i < nBandCount; i++ )
	GDALRasterBand* pMemBand = pMemDataset->GetRasterBand(i + 1);
	GDALRasterBand* pRasterBand = pDataSource->GetRasterBand(i + 1);
pMemBand->SetColorInterpretation(pRasterBand->GetColorInterpretation());
	pMemBand->SetOffset(pRasterBand->GetOffset());
	pMemBand->SetScale(pRasterBand->GetScale());
	pMemBand->SetUnitType(pRasterBand->GetUnitType());
	BOOL bSuccess = FALSE;
	double nNullValue = pRasterBand->GetNoDataValue(&bSuccess);
	if (bSuccess == TRUE)
		GDALColorTable* pColorTable = pRasterBand->GetColorTable();
		if (pColorTable != NULL)
			GDALColorEntry colorEntry;
			pColorTable->GetColorEntryAsRGB((int) nNullValue,
&colorEntry);
			hr = pMemBand->SetNoDataValue((double)
colorEntry.c4);
			if (FAILED(hr)) return hr;
		else
			hr = pMemBand->SetNoDataValue((double) nNullValue);
	if (!pMemBand->GetColorTable())
		pMemBand->SetColorTable(pColorTable != NULL ?
pColorTable->Clone() : NULL);
	unsigned char* pBytes = (unsigned char*) malloc(sizeof(unsigned
char) * nWidth * nHeight);
	memset(pBytes, 0, nWidth * nHeight);
	CPLErr err = pRasterBand->RasterIO(GF_Read, 0, 0, nWidth, nHeight,
pBytes, nWidth, nHeight, eBandType, 0, 0);
	if (err != CE_None)
	err = pMemBand->RasterIO(GF_Write, 0, 0, nWidth, nHeight, pBytes,
	if (err != CE_None)
	if (pBytes) delete [] pBytes;
if (pDataSource)
	GDALClose(pDataSource);
pDataSource = NULL;
if (m_pMemDataset)
	GDALClose(m_pMemDataset);
m_pMemDataset = pMemDataset;
Martin Chapman
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam
Sent: Friday, March 07, 2008 10:22 AM
To: Christiaan Janssen
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Loading from a stream/memory rather than a file
Christiaan Janssen wrote:
> Does anyone know if it is possible to create/open an image with GDAL using
a
> stream or chunk of memory instead of a file? This would be useful in
writing
> a caching mechanism but also to do in memory and other non file based
> processing.
Cristiaan,
Some driver utilize the VSI*L "virtual io" layer for file access, and then
you can either right custom file handlers, or more likely use the existing
in-memory VSI*L implementation.
This is likely the best explanation of the mechanism:
   http://www.gdal.org/cpl__vsi_8h.html#66e2e6f093fd42f8a941b962d4c8a19e
gdal/frmts/wcs/httpdriver.cpp is a simple example of it's use for reading
from memory.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
