[gdal-dev] Building with SEH
Martin Chapman mchapman at texelinc.com
Wed Mar 12 16:05:23 EDT 2008
Even,
I am using gdal 1.5.0 on windows xp pro and the buggy shape did indeed crash
my application.  I see the fix but I was wondering if there will be a 1.5.1
release soon?  Also, thanks for the info on this fix.
Best regards,
Martin
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Even Rouault
Sent: Wednesday, March 12, 2008 1:24 PM
To: Chris Howell
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Building with SEH
I won't really answer on the SEH part. I think that you'll still have to
live
with the fact that a remaining bug may cause memory corruption etc that will
cause bugs elsewhere, etc... My experience showed me that If you really want
to be sure that some library won't crash your application, the only reliable
solution is to link it to a process with which your main application
communicates through TCP/IP, pipes, or whatever... Or to provide enough
information to help us fix the bugs.
So, as far as broken shapefiles are concerned, there's a pending patch to
shapelib attached to http://trac.osgeo.org/gdal/ticket/2218. This would be
great if you could test it on your broken shapefiles and report if that
solves your problem.
Best regards,
Even
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
