[gdal-dev] Re: [GRASS-dev] Re: gdalwarp -co COMPRESS issues
Maciej Sieczka tutey at o2.pl
Sat Mar 15 05:22:30 EDT 2008
Hamish pisze:
> I too have been bitten by trying to gdalwarp and compress in the same
> step; will you take a document patch?
For now we don't know if/how r.out.gdal and gdalwarp compression issues
are connected:
MS: Could this r.out.gdal issue be related to gdalwarp issue?
FW: It might, or might not be. It is hard to know without analysis.
So, maybe there is a defect in r.out.gdal independent of GDAL issue or
maybe not.
If there is, then rather fix it than document it, if possible.
If there isn't (ie. GDAL is the culprit) - document it and wait till
it's fixed in GDAL.
Too litle known to decide now.
Maciek
