[Gdal-dev] GDAL vs ArcGIS raster calculator
joosthoek jelmer.oosthoek at tno.nl
Sat Mar 15 08:45:09 EDT 2008
I was wondering if someone knows if there is a GDAL alternative for the
following ArcGIS Raster Calculator code:
select ( merge ( setnull ( [raster] > 32767 , [raster] ) , ( [raster] -
65536 ) ) , 'value <> -32768' )
The input raster is 16-bit DTM data and as far as I know this code sets the
values to meters with correct datum.
I was trying the gdal_translate -scale option but that didn't work somehow
(I tried -scale 0 65535 -32768 32767). Someone has a better idea?
View this message in context: http://www.nabble.com/GDAL-vs-ArcGIS-raster-calculator-tp16056156p16056156.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080315/820ac3d1/attachment-0001.html
