[gdal-dev] FWTools 2.1.0 compiled in debug mode
Martin Chapman mchapman at texelinc.com
Tue Mar 18 00:44:15 EDT 2008
Frank,
Thank you for that explanation.  I think that is the problem, that I am
using another version of Python on my system.  By the way, the latest GDAL
1.5.1 RC4 works fine for me on Windows.  Thanks again for all the hard work
you guys do.
Best regards,
Martin
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Monday, March 17, 2008 9:07 PM
To: Martin Chapman
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] FWTools 2.1.0 compiled in debug mode
Martin Chapman wrote:
> Ok, I had another proj.dll in my path from another install so that problem
> is fixed but now I am having a problem with python.  Is there anything I
> should know about python being installed with FWTools?
Martin,
That's a rather open-ended question, and likely more suitable for the
FWTools
list.
The FWTools python is relatively old (2.3 I think on win32).  It may be
partially stripped down (some apparently unneeded stuff removed).  It is
also not "properly installed" so it won't be used from cmd.exe or the
desktop explorer to execute .py files by default.  It will be the default
python.exe in the path in the FWTools shell though.
You should assume that you cannot use other Python's with FWTools
python extensions unless you are very careful to match versions of python.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
