[gdal-dev] ogr2ogr, shapefile 2 postgis
Paal Sund paalsund at gmail.com
Thu May 1 17:09:07 EDT 2008
I am getting the following error while loading a shapefile to postgis
using ogr2ogr interactively from 'DOS' command window (cmd):
ogr2ogr -f "PostgreSQL" -a_srs "EPSG:32633" PG:"<some values>"
33_n5000_bygg_punkt.shp -nln n5000_bygg_pun
ERROR 1: INSERT command for new feature failed.
FEIL: invalid byte sequence for encoding "UTF8": 0x86
HINT: This error can also happen if the byte sequence does not match the
encoding expected by the server, which is controlled by "client_encoding".
Command: INSERT INTO "n5000_bygg_pun" (wkb_geometry , "area",
"perimeter", "kupu
nkt_", "kupunkt_id", "objtype", "ptema", "tett_id", "navn", "fyr_id",
"oppdatert
") VALUES (GeomFromEWKT('SRID=32768;POINT (897350 7911435)'::TEXT) ,
0.00000, 0.00000, 11, 503, 'Tettsted', 4007, 860
2, 'Honningsvåg', 0, 20010301)
ERROR 1: Terminating translation prematurely after failed
translation of layer 33_n5000_bygg_punkt
My ogr2ogr is from the latest FWTools, running on Windows XP 2002 sp2.
My PostGIS is from the latest windows binaries (postgresql 8.3 and the
application stack builder)
Any clues? The error message seems to point in the encoding direction.
My shapefile has 1252 encoding.
I havent done anything with encoding stuff in postgrsql.
Help appreciated,
best Pål Herman
