[gdal-dev] [OGR] Problems with the VRT driver
Alexandre Gacon alexandre.gacon+gdal at gmail.com
Wed May 21 04:17:45 EDT 2008
I would like to use ogr2ogr to convert a csv file to a shapefile.
Following the documentation of the csv driver, I shall use a VRT file to
handle the conversion.
After several unsuccessful tries on my own files, I decided to try the
sample indicated in the csv driver documentation. But the sample does not
work : ogr is unable to find the appropriate driver.
Could someone help me, please ?
Sincerelly,
Alexandre Gacon
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080521/48fe47b3/attachment.html
