[gdal-dev] OGR DeleteFeature throws memory exception
Brad Grinstead bgrinstead at iavo-rs.com
Mon Nov 10 15:03:54 EST 2008
Frank,
I appreciate the response, but I finally found out that certain OGR-specific variables were not being handled correctly, which caused a latent memory leak leading to the problem I reported.  I think those have all been tracked down now.
Brad G.
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Monday, November 10, 2008 11:48 AM
To: bgrinstead at iavo-rs.com
Cc: gdal-dev
Subject: Re: [gdal-dev] OGR DeleteFeature throws memory exception
Brad Grinstead wrote:
> I am wondering if someone has experienced a memory access violation
> when attempting to delete OGRFeatures.  I am running the latest build
> off the trunk and have been able to find no information regarding this error.
Brad,
Can you confirm that you are operating using the C# bindings for OGR?
Your code looks ok to me, but I'm not completely clear on the built-in disposal logic for features in C#.
Also, you don't seem to have mentioned the GDAL/OGR version which could be important to diagnosing the problem.
Best regards,
