[gdal-dev] OBus error when writing GeoTiffs
Fri Nov 14 14:26:24 EST 2008
Chris Garrard wrote:
> Hi,
> I've compiled GDAL 1.5.3 on Solaris 10, using internal support for tiff
> and gtiff.  When I try to create a new GTiff using gdal_translate, it
> fails with "OBus Error".  That's all the information I get.
> The problem is only with writing GTiffs, not reading them.  I can
> convert a tiff to another format, get information about them with
> gdalinfo, and am using them with MapServer built with GDAL support.  I
> can write to other formats without a problem.
Chris,
Any chance of running things in gdb or dbx and getting a traceback?
I assume this is Solaris on Sparc?  Often problems on this architecture
are byte order or "double alignment" issues.
Is this a 32bit or 64 bit build?  Are you using the GNU or Sun tool chains?
Best regards,
