[gdal-dev] using GDALCreateCopy and changing only the datatype
Mon Nov 24 11:55:47 EST 2008
Yann Chemin wrote:
> Hello,
> I would like to use GDALCreateCopy and change the datatype from int32
> to float32.
>         GDALDatasetH hDatasetOut0;
>         hDatasetOut0 = GDALCreateCopy( hDriver1, ndviF,
>                                 hDataset1,FALSE,NULL,NULL,NULL);
>         GDALRasterBandH hBandOut0;
>         hBandOut0 = GDALGetRasterBand(hDatasetOut0,1);
Yann,
Generally speaking to do this with CreateCopy() you would need to create
an intermediate virtual dataset with the altered pixel data type.  This is
how the -ot flag of gdal_translate works.   You can review the
gdal_translate.cpp code as an example, though it is somewhat involved.
Best regards,
