[gdal-dev] Shift/Translate vector data within the same coordinate system
Andreas Neumann a.neumann at carto.net
Tue Oct 7 02:42:53 EDT 2008
I wonder if ogr2ogr can translate/shift vector data within the same
coordinate system. In Postgis I would use ST_Translate(geometry, float8,
float8, float8) to solve my problem.
I have data that is in the swiss coordinate system (metric, scale 1:1),
but not correctly georeferenced. All vector data should be translated
according to a given x/y offset. The output should be again in the swiss
coordinate system.
I looked up the documentation of ogr2ogr at
http://www.gdal.org/ogr/ogr2ogr.html but couldn't find a way to do what I
want.
Thanks for any hint on how to do this with ogr, if it is possible at all.
Andreas
Andreas Neumann
Böschacherstrasse 6, CH-8624 Grüt/Gossau, Switzerland
Email: a.neumann at carto.net, Web:
* http://www.carto.net/ (Carto and SVG resources)
* http://www.carto.net/neumann/ (personal page)
* http://www.svgopen.org/ (SVG Open Conference)
* http://www.geofoto.ch/ (Georeferenced Photos of Switzerland)
