[Gdal-dev] gdal_grid: Comments from a new player
Fodder cryan at csse.com.au
Wed Oct 22 02:01:36 EDT 2008
The latest version of GdalGrid (in FWTools) seems to not use the radius
values properly for the Nearest algorithm. In my project, I used 4000 for
both but I ended up with very little circles around the data points. Using
the same radius values for the Inverse Distance algorithm produced values
for the entire display (which is what I would expect because my entire
project is 4000x4000).
Andrey Kiselev wrote:
> On Sun, Jun 01, 2008 at 05:29:26PM -0700, Fodder wrote:
>> - One more thing I've noticed. The 'nearest' interpolation algorithm
>> doesn't seem to accept the defaults of 0 (meaning whole array) for
>> radius1 & radius 2, when used like this:
> That is know bug and it was fixed:
>  http://trac.osgeo.org/gdal/ticket/2237
> Just grab the newer GDAL.
> Best regards,
> Andrey
> Andrey V. Kiselev
> ICQ# 26871517
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
View this message in context: http://www.nabble.com/gdal_grid%3A-Comments-from-a-new-player-tp17591913p20104473.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
