[gdal-dev] error allocatint [sic] destination buffer
Even Rouault even.rouault at mines-paris.org
Thu Oct 23 17:29:18 EDT 2008
The only idea I have is pretty obvious and I guess you'd already have it, you
probably require more memory than available. The --config GDAL_CACHEMAX
500 -wm 500 options require at least 1 GB. Otherwise it's a more subtle bug.
Unfortunately it's not very practical to try to reproduce it as your input
datasets are pretty big to download.
I've downloaded the first two files and observed that they are at the same
resolution and projection so you could probably use gdal_merge.py instead
