[gdal-dev] MEM size limit
Ozy Sjahputera sjahputerao at missouri.edu
Mon Sep 22 14:02:01 EDT 2008
Thanks, Frank. That helps a lot.
ozy
Frank Warmerdam wrote:
> Ozy Sjahputera wrote:
>> Hello everyone,
>> According to the documentation in gdal.org, the in-memory file format
>> (MEM) has a 2GB size limit. I recently used MEM to process an image
>> whose size is larger than 2GB without encountering any error message.
>> The output seems to be fine as well. Has the MEM driver been upgraded
>> to handle image > 2 GB. I am using GDAL v1.5.2.
> Ozy,
> Yes, it appears that as part of treating bug #1503 this limitation was
> removed on 64bit platforms.  I have removed the 2GB limit mention in
> the formats_list.html file.
> Best regards,
