[gdal-dev] Spherical Mercator projects and overviews?
Stephen Woodbridge woodbri at swoodbridge.com
Thu Apr 9 12:25:04 EDT 2009
Frank Warmerdam wrote:
> Stephen Woodbridge wrote:
>> Hi all,
>> I have a question regarding imagery in spherical mercator projection
>> in geotiff images. Do overviews work correctly?
>> For example, I use EPSG:4326 and build lots of overviews and I can
>> zoom in and out and pan without a problem. Can I do the same thing
>> with EPSG:900913 (spherical mercator projection).
>> I'm working with LandSat imagery over large area and scale ranges.
> Steve,
> I can't see any reason that overviews would not work on spherical
> mercator when they work on images in other coordinate systems.  The
> overview handling is independent of the georeferencing.
Frank,
Thanks this is what I was hoping the answer would be.
My fear was that I would run into something like UTM zones and that you
can not have one global data set in UTM. So spherical Mercator is
projects the world into a single x-y plane similar to the way
geographical is treating the global as stretched onto a single x-y
plane.  This seems reasonable, I just never thought about it before.
Now I get to reproject everything yet again :)
Thanks,
   -Steve
