[gdal-dev] Problem with OGRCreateCoordinateTransformation
Mateusz Loskot mateusz at loskot.net
Fri Apr 10 11:10:04 EDT 2009
Reinaldo Escada Chohfi wrote:
> Hello,
> The code compiles because it is part of a bigger program.  This is
> just the portion on Coordinate Transformation.
It doesn't matter actually how big is the program.
Howard is referring to this particular assignment:
OGRSpatialReference oSourceSRS, oTargetSRS;
oSourceSRS="EPSG:4326";
oTargetSRS="EPSG:4989";
It is invalid C++ code and it would be surprising if this code even
compiles, no matter what compiler you use.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
