[Gdal-dev] GDAL SUPPORTS ONLY MSGN(NAT) AND NOT MSG (HRIT) FILES ?
APOSTOLOS agiannas at geo.auth.gr
Fri Apr 10 12:42:53 EDT 2009
Dear list
SINCE  last week i have been strugling installing MSG DRIVER. I managed to install MSG DRIVE but i can convert only native format and NOT HRIT!!!!
 I really wander if ANYONE has read MSG2 HRIT dataset?
Because THE FILE  http://www.gdal.org/frmt_msgn.html says that GDAL supports reading only of MSG native files.
i HOPE SOMEONE HAS FACED THE SAME PROBLEM AND ANSWER MY QUESTIONS
THANKS
View this message in context: http://n2.nabble.com/GDAL-SUPPORTS-ONLY-MSGN%28NAT%29-AND-NOT-MSG-%28HRIT%29-FILES---tp2617105p2617105.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
