[Gdal-dev] GDAL seems unable to translate CIB data set
Thu Aug 6 11:45:37 EDT 2009
Ollie Newman wrote:
> I am having a problem accessing some CIB data using GDAL.  The dataset in
> question is a 44544 by 56832 pixel image split across 1073 files and is 1m
> resolution sat imagery.  The data will open OK in ArcMap so I am reasonably
> confident that the data is not corrupted.  Using OpenEV I can open the
> dataset but only the first tile and a bit has any data, the rest is blank.
> gdal_translate fails wth the following errors
> E:\CIB\RPF>gdal_translate -of GTiff NITF_TOC_ENTRY:CIB__1M_2_2:./a.toc
> out.tif
> Input file size is 44544, 56832
> 0Warning 1: Lost metadata writing to GeoTIFF ... too large to fit in tag.
> Warning 1: For .\NI425J2\01LGBN2B.I42, assert
> 'fabs(adfGeoTransform[GEOTRSFRM_TOPLEFT_X] - nwLong) < 1e-10' failed ERROR
> 1: IReadBlock failed at X offset 0, Y offset 0 ERROR 1: GetBlockRef failed
> at X block offset 0, Y block offset 0 <execution stops>
Ollie,
Can you make .\NI425J2\01LGBN2B.I42 available for inspection?  I imagine Even
will need to comment on the particulars of the RPFTOC driver - I see this
assertion is coming from it, not the NITF driver.
Best regards,
