[gdal-dev] reprojection HDF / GCP extraction
Becker, Thomas thob at dmu.dk
Mon Aug 10 08:00:50 EDT 2009
Hi all,
I have a couple NOAA-15 images as HDF-EOS files which I would like to reproject to WGS84. The data carry a subgroup called 'Geolocation Fields' holding latitude and longitude for each pixel in separated arrays. Reading the files with gdalinfo leads to the output at the end of this posting.
Out of the HDF-EOS format I would like to create a correct georeferenced image (GTIF). One which will not look like a swath scanned image, but a skewed and correctly referenced one.
Using gdalwarp leads to the message: There is no affine transformation and no GCPs.
Since the coordinates for the centre of each pixel are stored in the before mentioned arrays, is there a way to extract GCPs out of the data.
Thanks for your help.
Best regards,
Thomas
gdalinfo output:
Driver: HDF4/Hierarchical Data Format Release 4
Files: amsua15_2000.034_08964_0104_0258_GC.eos
Size is 512, 512
Coordinate System is `'
Metadata:
  HDFEOSVersion=HDFEOS_V2.4
Subdatasets:
  SUBDATASET_1_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit 8964:23800.37 MHz
  SUBDATASET_1_DESC=[851x30] 23800.37 MHz Orbit 8964 (32-bit floating-point)
  SUBDATASET_2_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit 8964:31400.42 MHz
  SUBDATASET_2_DESC=[851x30] 31400.42 MHz Orbit 8964 (32-bit floating-point)
  SUBDATASET_3_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit 8964:50299.91 MHz
  SUBDATASET_3_DESC=[851x30] 50299.91 MHz Orbit 8964 (32-bit floating-point)
  SUBDATASET_4_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit 8964:52799.39 MHz
  SUBDATASET_4_DESC=[851x30] 52799.39 MHz Orbit 8964 (32-bit floating-point)
  SUBDATASET_5_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit 8964:53595.41 +- 115 MHz
  SUBDATASET_5_DESC=[851x30] 53595.41 +- 115 MHz Orbit 8964 (32-bit floating-point)
  SUBDATASET_6_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit 8964:54399.53 MHz
  SUBDATASET_6_DESC=[851x30] 54399.53 MHz Orbit 8964 (32-bit floating-point)
  SUBDATASET_7_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit 8964:54940.64 MHz
  SUBDATASET_7_DESC=[851x30] 54940.64 MHz Orbit 8964 (32-bit floating-point)
  SUBDATASET_8_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit 8964:55498.70 MHz
  SUBDATASET_8_DESC=[851x30] 55498.70 MHz Orbit 8964 (32-bit floating-point)
  SUBDATASET_9_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit 8964:57290.33 MHz
  SUBDATASET_9_DESC=[851x30] 57290.33 MHz Orbit 8964 (32-bit floating-point)
  SUBDATASET_10_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit 8964:57290.33 +- 217 MHz
  SUBDATASET_10_DESC=[851x30] 57290.33 +- 217 MHz Orbit 8964 (32-bit floating-point)
  SUBDATASET_11_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit 8964:57290.33 +- 322.2 +- 48 MHz
  SUBDATASET_11_DESC=[851x30] 57290.33 +- 322.2 +- 48 MHz Orbit 8964 (32-bit floating-point)
  SUBDATASET_12_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit 8964:57290.33 +- 322.2 +- 22 MHz
  SUBDATASET_12_DESC=[851x30] 57290.33 +- 322.2 +- 22 MHz Orbit 8964 (32-bit floating-point)
  SUBDATASET_13_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit 8964:57290.33 +- 322.2 +- 10 MHz
  SUBDATASET_13_DESC=[851x30] 57290.33 +- 322.2 +- 10 MHz Orbit 8964 (32-bit floating-point)
  SUBDATASET_14_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit 8964:57290.33 +- 322.2 +- 4.5 MHz
  SUBDATASET_14_DESC=[851x30] 57290.33 +- 322.2 +- 4.5 MHz Orbit 8964 (32-bit floating-point)
  SUBDATASET_15_NAME=HDF4_EOS:EOS_SWATH:"amsua15_2000.034_08964_0104_0258_GC.eos":Orbit 8964:88997.00 MHz
  SUBDATASET_15_DESC=[851x30] 88997.00 MHz Orbit 8964 (32-bit floating-point)
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,  512.0)
Upper Right (  512.0,    0.0)
Lower Right (  512.0,  512.0)
Center      (  256.0,  256.0)
