[gdal-dev] Re: Problem with nodata values
Wed Aug 12 10:13:42 EDT 2009
On Tue, Aug 11, 2009 at 12:53 PM, Hermann Peifer<peifer at gmx.eu> wrote:
> Markus wrote
>> This works:
>>   ...         -srcnodata "-32768" -dstnodata "-32768" -wo
>> "INIT_DEST=-32768" \
> I was taking a similar approach when warping several input tiffs into a
> single output tiff. It looks to me that for each input file, the output file
> is completely reset to the INIT_DEST value, overwriting the values from
> previously processed input files. The final output file did only contain the
> warped values of the last input file in the upper right corner, anything
> else was NODATA. I am wondering if this is rather a feature or a bug.
Hermann,
INIT_DEST should usually only be used for the first run when creating
the file.  The noted behavior is intentional.
Best regards,
