[gdal-dev] UTF-8 String Support in GDALOpen() and OGRSFDriverRegistrar::Open()
Chaitanya kumar CH chaitanya.ch at gmail.com
Mon Aug 31 10:10:36 EDT 2009
Louis,
GDAL/OGR usually supports utf-8 encoding. I just don't know where it doesn't
support.
Can you provide the details of the OS you are working on? Also, some sample
file names that caused you problems will come handy.
I presume you are working in C/C++.
On Mon, Aug 31, 2009 at 6:37 PM, Lodewijk Pool <louis.pool at gmail.com> wrote:
> Hi All,
> I'm having problems opening Raster and Vector Datasources that have
> filenames and paths with special characters. I'm using GDALOpen for Raster
> sources and OGRSFDriverRegistrar::Open() for Vector sources, the strings I
> pass for the filenames are UTF-8 encoded. Does anyone know whether these
> functions support UTF-8 encoding, and if not, whether there are any other
> API entry points that do support UTF-8 and/or UTF-16?
> Thank you in advance,
> Louis.
>  _______________________________________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20090831/2d8092eb/attachment.html
