R:[gdal-dev] Re: GDAL/WMS and Proxy
stefano.moratto at gmail.com stefano.moratto at gmail.com
Wed Dec 2 05:41:22 EST 2009
SET http_proxy=server:port should be an lib_curl option. I use it but It
did not work (I'm under XP)
Since I would like to use GDAL in my delphi gis application I need to set
this option programmatically.
I will modify gdalhttp.* and dataset in gdal\trunk\frmts\wms in order to
add this option.
I would be nice to a have a global GDL function to set PROXY information,
like CPLSetHttpProxyInfo because the modification I'm going
to introduce will concern only the WMS driver. but not other drivers that
use lib_curl
Stefano
Il giorno 02/dic/2009 11.00, Jukka Rahkonen <jukka.rahkonen at mmmtike.fi> ha
scritto:
> Stefano Moratto gmail.com> writes:
> > I set proxy information as described but It did not work.
> Have you tried to set proxy in the Windows command window first? I
> believe the
> command is
> It would be good to have an option to set it in the xml file also.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20091202/7840b097/attachment.html
